It is currently Mon Jul 21, 2025 9:14 am
PostPosted: Tue Jun 26, 2007 2:22 am
I made my first 2 "real" bridges with my new design. I'm pretty happy, but they are a pain to polish, especially in the corners of the lower shelf.
These are Macassar Ebony, one with a layer of manzanita. The manzanita one is being a bit more trouble to polish. I think the adhesive is causing me some trouble.
I am using a Dremel felt wheel to try to get into that corner. Does anyone have any suggestions for polishing these problem areas?
Thanks!
http://i9.photobucket.com/albums/a53/Slsaville/Oak%20guitar/ IM000277.jpg">
PostPosted: Tue Jun 26, 2007 2:30 am
Good job Steve!
PostPosted: Tue Jun 26, 2007 2:33 am
Steve, I like them a lot. A couple of comments from my designer's eye, do with them what you want.
1) I think the two tone wood is a little much. It will likely bring the eye right to the bridge and prevent it from seeing the rest of the guitar as a whole.
2) I know this would alter your design a bit but it would also make polishing easier. If you look at the second photo down, it appears less shelf-like and more scooped. Similar to the traditional wings of a "normal" bridge, but rotated 90 degrees. Might be worth looking into.
Again, when it comes to my advice and opinions, you get what you pay for.
Great work!
PostPosted: Tue Jun 26, 2007 2:51 am
Paul,
Thank you for your comments.
1) The manzanita layer was requested by the client. It has other manzanita appointments on it. Generally speaking, I agree with you, but on this guitar, I think it works.
2)That corner has a small radius. Are you suggesting a much larger radius? I used a router bit that I rounded the corner on. I was thinking of increasing that corner radius. It sounds like you are suggesting more than just an increase in radius, almost a scoop instead. (That would make it look a lot like another bridge and I was trying to avoid being that close.)
PostPosted: Tue Jun 26, 2007 2:57 am
I really like them, Steve. I think if the colorful layer is supporting other design elements like... HS overlay, rosette, and binding, the two tone bridge could be really nice.
The only thing I can think of for getting into the corners, is to sand blast it. ???
Long
PostPosted: Tue Jun 26, 2007 5:07 am
Way 2 Go Steve, those are quite nice.
PostPosted: Tue Jun 26, 2007 5:31 am
Really nice looking bridge, Steve.  Great lines.  Good, original design thinking, IMO.
PostPosted: Tue Jun 26, 2007 6:16 am
Inside corners are such a pain to sand or polish.
PostPosted: Tue Jun 26, 2007 6:53 am
I agree with Paul. I was looking at it, and thinking you could still achieve that nice swirled look if you simply ramped up to the top profle, or used a bigger radius rather than running flat and into the curved ledge. If you left the intersection crisp rather than rounded, it might help to keep the look you're after.
PostPosted: Tue Jun 26, 2007 7:59 am
Here is a shot of that bridge with the guitar.
Does that work better for anyone seeing it with the guitar?
The binding is manzanita and the back and sides are oak.
PostPosted: Tue Jun 26, 2007 8:09 am
It didn't bother me before, but that looks really awesome!  Great continuity of design.
PostPosted: Tue Jun 26, 2007 8:20 am
PostPosted: Wed Jun 27, 2007 2:53 am
I think if you changed the relative thickness of the wo woods to place the glue line on the vertical surface the polishing problem would be more like the solid bridge.
I like it but it does draw my eye to the bridge.
Nice design.
PostPosted: Wed Jun 27, 2007 3:03 am
The shelf concept is disturbing to my eye. I would much rather see a uniform transition from thinnest to thickest. I like the dual color but feel that the reveal as it transitions would be more dramatic. It also solves the polishing problem.
PostPosted: Wed Jun 27, 2007 3:14 am
Maybe having less of a steep cut and more ramped would make it easyer to pollish also, but,
I like it alot and think it gives the instrument your own design signature.
Wade
Wade
Nashua, NH
http://www.wadefx.com
PostPosted: Wed Jun 27, 2007 3:23 am
Steve, you are right that I was initially thinking of a ramp look. However, if you went with a big radius, maybe 1/2 - 3/4" you could achieve your stepped look and still keep the transition smooth. It for sure will be easier to polish.
